1998 Toyota Tacoma AC Clutch Stays On
TOYOTA
GR8FL
I have a 1998 Toyota Tacoma w/105,000 miles on it.
The engine is a 2.4 l , 4 cyl, 2wd, w/regular cab.
For some reason the AC Clutch will not disengage when the outside air temperature is below +/- 67 degrees F even though the AC switch is turned Off. This started to happen last fall. The AC clutch was engaged all winter (I justed realized it) and now that the temperatures are escalating it is becoming less freguent The AC cools properly and the clutch engages/disengages when the switch is turned on. Nothing is keaking. I'd replace the clutch if I was sure that it was the problem but I'm wondering if it might be something else. Can You Help Please?
May 7, 2007 at 9:52 AM
  • 75,988 POSTS
[quote:f11dca37e2="gr8fl"]I have a 1998 Toyota Tacoma w/105,000 miles on it.
For some reason the AC Clutch will not disengage when the outside air temperature is below +/- 67 degrees F even though the AC switch is turned Off. This started to happen last fall. The AC clutch was engaged all winter (I justed realized it) and now that the temperatures are escalating it is becoming less freguent The AC cools properly and the clutch engages/disengages when the switch is turned on. Nothing is keaking. I'd replace the clutch if I was sure that it was the problem but I'm wondering if it might be something else. Can You Help Please?[/quote:f11dca37e2]
Could be a pressure switch or relay
May 7, 2007 at 3:31 PM
Suggested Repair
Check the AC pressure switch and the AC clutch relay, since the compressor clutch stays engaged below about 67 F with the AC switch off.
Conversation Summary
The owner of a 1998 Toyota Tacoma with a 2.4L engine reports that the AC clutch stays engaged when the outside temperature is below about 67 F even with the AC switch off. The system cools properly, the clutch cycles normally when the switch is on, and there are no leaks. The expert suggests the cause could be a pressure switch or relay.
