92 Carolla
1992 TOYOTA
EMYDINAE
Toyota Carolla DX 92 (automatic)
We have changed axles due to the damage of the CVs several days ago. Since then, the car seemed to be normal till yesterday. Yesterday, after driving about 30 meters, the car stopped proceeding as if the transmission was in neutral. I attempted to change the gear (R, D, 2, L), and it did not do anything. We suspected that the fluid was too low, so we added the fluid. But, it does not work still.
Do you have any idea?
Jan 12, 2006 at 1:41 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the axle installation and loss of drive inspected by the repairer before further operation. Arrange recovery if the car cannot move safely.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
CHEVY55
  • 9 POSTS
Could be your differential. I broke mine while slowing
down on an exit ramp. Seems to be a weakpoint with
89-92 Corollas.
Jun 14, 2006 at 7:12 AM
SWEEP2WIN
  • 21 POSTS
I have a 91 corolla and experienced the same problem. The transmission shifter linkage in the engine compartment was checked first. Then the AT fluid level. Both were okay. I suspect you have a faulty new part if one was even installed if you trust your mechanic or actually saw the new parts coming in. The passenger side axle (the longer one) was my problem. Without it being in good condition, the trasmission will not move the car. Tell your mechanic to inspect it again.
Jun 23, 2006 at 9:51 PM
Discussion summary
92 Carolla
A 1992 Corolla automatic stopped moving in every selected drive range shortly after axle replacement. Adding transmission fluid did not restore movement.
Reported outcome: The original owner did not report a confirmed cause or repair.
Other participants described differential and axle faults on their own cars. Those experiences do not establish this Corolla's fault, and the correct fluid level was not documented.
Read the original discussion
