2007 Other Toyota Models Stuck valve stem caps
2007 TOYOTA
27,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOELCONSTANTZ
My aftermarket chrome valve stem caps are stuck to the valve stems making it hard to remove the caps to check the tire pressure without destroying the valve stems. Is there a product I can use to losen the caps? Thanks in advance for your response.
Regards,
Joel Constantz
Aug 15, 2009 at 11:02 AM
SERVICE WRITER
  • 9,123 POSTS
Contact the manufacturer or installer first to avoid any warranty issue.
I would wrap a thin piece of rubber, like a tire tube for example, around the valve stem and cap. Then use pliers or similiar to try to twist it off..
Aug 26, 2009 at 12:07 AM
