Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Other
Engine
Serpentine Belt
Replace/Remove
2004 Other Toyota Models how to replace serpentine belt
2004 TOYOTA
42,000 MILES • 4 CYL • 2WD • AUTOMATIC
THEBOYS
MEMBER
1 POST
42,000
Jul 12, 2008 at 2:13 AM
KHLOW2008
Experienced Mechanic
Hi theboys,
On the belt tensioner bearing bracket you would notice a 19mm hex head. Turn it clockwise to release the belt tension and get belt off the pulleys.
Note the belt routing before you attempt to remove it.
Jul 14, 2008 at 1:52 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
