2004 Other Toyota Models how did this happen?
2004 TOYOTA
24,000 MILES • 4 CYL • AWD • AUTOMATIC
GREG3
I brought my matrix in for regular service and they replaced front pads and wheel bearing a day later the axle from the side they did bearing replacement on came apart at the wheel. Did the mechanic screw up?
Oct 5, 2008 at 5:29 AM
GRSMNKY
  • 33 POSTS
you bet your ball bearings the mechanic screwed up. My guess is either he/she forgot to torque the axle nut or just forgot to install the nut all together. Glad you are alive and able to write this. Since your life and your investment (car) was put in jeopardy, demand compensation for any work done on your car that led to this, as well as repairs to it after the incident. Hint on a settlement to help you forget this ever happened and help you through this troubled by economy times. After all is done, go to a better place for further car service. Good luck.
Feb 14, 2009 at 10:08 AM
