2003 Other Toyota Models Car does not shift into gear when c
2003 TOYOTA
TIP-C
Transmission problem
2003 Other Toyota Models Engine Size unknown Four Wheel Drive Manual 55,000 miles
When clutch is pressed, the gear lever will not go into any of the gears. What could be causing this problem and what needs to be done to fix it?
Thank You,
Dennis
Mar 9, 2008 at 10:58 AM
  • 31,937 POSTS
Hi there, if this is just a problem with a cold transmission, (first thing in the morning) try a fully synthetic gear oil in the transmission, this can often help.
Mark (mhpautos)
Mar 10, 2008 at 5:03 PM
