2000 Other Toyota Models Timing Belt
2000 TOYOTA
78,758 MILES • 6 CYL • 4WD • AUTOMATIC
NATALIA
It was recommended that at 60K I change the timing belt. However, when I took my truck in for service at that time - I was told that it was not necessary. At present, I hear a noise like a belt may be worn. What do you suggest as far as the timing belt? What should be the price of repair - high/low? Thanks...
May 14, 2008 at 7:32 AM
  • 31,937 POSTS
Hi there,
If you have a concern about a noise you should insist that they inspect, as if it is a timing belt or pulley, water pump problem and it fails, you will be up for a very large repair bill. To have the belt replaced will take about 2 Hrs, so this is not a huge expense for piece of mind... Timing belts should be replaced depending on the engine around the 100 K Kms, or 90 months.
Mark (mhpautos)
May 14, 2008 at 10:28 AM
