2000 Other Toyota Models no pressure
2000 TOYOTA
119,000 MILES • V8 • 4WD • AUTOMATIC
APK2APK
2000 toyota tundra changed passenger side caliper lost all brake pressure wont bleed so changed master cylinder still have same problem any solutions?
Apr 15, 2010 at 3:14 AM
2CARPRO JACK
  • 11,533 POSTS
Did you bleed the system? if so when you bled the caliper did you get solid fluid or was it airy? Did you bench bleed the master cylinder before installing it
? If no to any of these, you may need to take it down and have the system power bled to force the air out. A new master is full of air and if it isnt bench bled, you will introduce all of that air into the system
Apr 15, 2010 at 1:36 PM
