2000 Other Toyota Models Check Engine Light is ON
2000 TOYOTA
46,120 MILES • 4 CYL • FWD • AUTOMATIC
BATUKA
My car is Toyota Vitz. Mileage: 45120km. Manufactured in 2000 March. During last winter I used to park my car in a garage which doesn't have any heating system. I know it's bad for car, but I didn't have any choice. At that time the CHECK ENGINE light used to remain on while I drive. I thought that's because of cold condition. But now it already got warm outside, however that light still remains on, which makes me really worry about my car. I went to the local repair shop to find out the problem, they said the spark plugs caused the problem. But that didn't work, still the light is on. At the repair shop I changed the spark plugs, engine oil and oil filter. Please give me an advice to deal with my car. Thank you.
Mar 28, 2008 at 9:56 PM
  • 31,937 POSTS
Hi there,
You will have to get the fault code read and the code extracted this will give a unique code number that will correspond with the faulty item. get this code extracted first.
Mark (mhpautos)
Mar 28, 2008 at 10:13 PM
BATUKA
Thank you, I'll make sure the error code and get here back. Thanks again I do appreciate your prompt answer.
Mar 28, 2008 at 10:22 PM
BATUKA
I found the error code. They say: P0505 Idle System Malfunction.
Looking forward you...
Thanks
Mar 30, 2008 at 8:26 PM
  • 75,988 POSTS
P0505 relates to the idle air control valve -try cleaning it out and see what happens if it continues could be the valve itself-
Mar 30, 2008 at 8:49 PM
