1999 Other Toyota Models Ignition Problem
1999 TOYOTA
160,000 MILES • 4 CYL • 4WD • MANUAL
PNOLAN
Having Ignition problems. Replaced starter relay, and battery but still will not turn over, there is no power to the starter? When try to start truck dash lights dim, also if key is in on position and i push the break pedals lights dim?
Aug 13, 2008 at 9:47 AM
KHLOW2008
  • 41,814 POSTS
Hi pnolan,
Check the battery terminals connections and cable grounds at body and engine/tranmission.
I suspect a bad ground connection.
Aug 18, 2008 at 2:29 AM
