1999 Other Toyota Models
1999 TOYOTA
84,666 MILES • 4 CYL • 4WD • MANUAL
SHILTON
I have toyota tacuma 1999 4x4, after 5minuten that I fill water in my radiator is water disappeared to the oil pan, but the cilynderheadgasket have been renewed.
What is the problems is?
Jan 12, 2008 at 2:39 PM
  • 31,937 POSTS
Hi there,
You still have a problem with the head or the gasket, Was the head crack tested, checked for bend and warpage and re machined. Was the block cleaned off ALL old gasket material, was the head bolt tensions done as per specs. head gasket right way around? you have some checking to do.
Mark (mhpautos)
Jan 12, 2008 at 3:08 PM
