1998 Other Toyota Models Altenator
1998 TOYOTA
28,000 MILES • 6 CYL • 2WD • AUTOMATIC
WHEELY
Dear Sir,
When I am in traffic (idling) with the A/C turned on and the car lights, after about 30 minutes the battery light starts to come on and the power in the battery goes down to eleven volts. With the A/C off and the lights off it rises to about fourteen volts!
The engine idle speed is about 500RPM (is this too low?)
After 30/40 minutes the battery is nearly flat!
What do you think the problem is?
The car is a Toyota Aristo 3000 GTE Twin Turbo VVTI (1998)
Regards, Terence...
Aug 20, 2008 at 2:48 PM
  • 31,937 POSTS
HI there,
The engine idle speed is far to low, i would first have the A/C idle up inspected and if that is OK, have the engine idle speed re set, start here.
Mark (mhpautos)
Aug 20, 2008 at 4:25 PM
WHEELY
Hi Mark,
Thanks for the info. Do you you know what the idle speed should be set at, at idle (tick-over)?
Regards,Terence...
Aug 20, 2008 at 7:09 PM
  • 31,937 POSTS
Hi there , V6 idle speed and adjustment as per instructions. Mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_32.jpg
https://images.2carpros.com/forum/automotive_pictures/61395_snap_1_7.jpg
Aug 20, 2008 at 9:59 PM
