1995 Other Toyota Models Harmonic balancer
1995 TOYOTA
SCORAY
Engine Mechanical problem
1995 Other Toyota Models 4 cyl Two Wheel Drive
i am in the process of taking the front of engine off due to the plastic broken off the cam chain guides and have not been able to stop crank turning so that i can undo the nut in front of balancer if you can help in any way it would be greatly appriecated thank you
May 7, 2010 at 8:51 PM
  • 31,937 POSTS
Remove the starter and with an assistant get them to lock the ring gear with a large lever while you undo the bolt.
mark (mhpautos)
May 8, 2010 at 6:21 AM
