1995 Other Toyota Models Changing Issue of Transmission
1995 TOYOTA
208,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGGDAWG
I have a 1995 Toyota SR5 Truck, 4x4, Auto, V6. It will not change into Over Drive (OD) until the truck has gotten hot, or I'm thinking the transmission is hot. It is getting worse, it doesn't want to change in OD now, even after it is hot. Can you advise?
Nov 2, 2010 at 10:47 AM
KHLOW2008
  • 41,814 POSTS
Hi Biggdawg,
Check the OD solenoid. Quite often this solenoid sticks and would not be able to shift to OD.
Nov 5, 2010 at 2:01 AM
