1993 Other Toyota Models Warning Lights (change engine oil l
1993 TOYOTA
TYLERRESCH
Electrical problem
1993 Other Toyota Models Engine Size unknown Two Wheel Drive Automatic 200000 miles
I have a 1993 Toyota Lucida Van. I think it is the same as the previa although I am not sure. It is the 2.1 turbo diesal. I could be wrong on the liter displacement but I think there is only one turbo diesal model for it. Anyways my issue is this: I had the oil changed 3 weeks ago, the window sticker says that my oil change is good for another 4000 miles. About 30 miles ago the yellow bottom right chage oil light came on in my instrument panel. I am wondering how I can turn this off or if it means something more serious. I checked the oil and which looks fine and so does the oil level. I have had other OBDI cars and have had to turn off warning lights with a sequence of button pushing and things like this. Is there a sequence for turning off the light or do you think I should go get it checked out? Money is definitly an issue and I will not be owning the van for much longer. Any help would be great. Thank you!
Mar 30, 2008 at 11:24 AM
  • 75,988 POSTS
Try this disconnect the battery for 10secs and see what happens. On a gas model all you have to do is remove the EFI fuse-
Mar 30, 2008 at 3:40 PM
