HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Other
Drivetrain
Transfer Case
SPONSORED LINKS
1987 Other Toyota Models my truck has some acceleration prob
GMW3
MEMBER
1987 TOYOTA
Engine Performance problem
1987 Other Toyota Models 6 cyl Four Wheel Drive Manual
can anyone explain to me why my truck can't go over 55 mph it's like I floored it and it only goes 55
Sunday, September 26th, 2010 AT 3:40 PM
MECHANIC
Check exhaust system if its clogging-up and EGR valve operation
If its an EFI and timing properly-check the airflow meter and the throttle position sensor-
Carbuerator: Carb's main metering and power valve circuits
SPONSORED LINKS
Sunday, September 26th, 2010 AT 5:11 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1991 Toyota
Going Up Large Grades Sometimes My Toy 4runner 4x4 Looses Power And Sucks Up The Gas Any Ideas?
Asked by
jeffreymck7
1 ANSWER
1 IMAGE
1991
TOYOTA OTHER
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1993 Toyota Front Wheel Bearing Noise
Drive Train Axles Bearings Problem 1993 Other Toyota Models 4 Cyl Front Wheel Drive Manual What The Problem
Asked by
famieahmad
1 ANSWER
1993
TOYOTA OTHER
2014 Toyota Wheel Bearing Lubrication
Is 50,000 Miles The Right Mileage To Clean And Grease The Wheel Bearings?Kind Regards And Thanks A Lot In Advance.
Asked by
lacoste-cy
1 ANSWER
2014
TOYOTA OTHER
1999 Toyota Gearbox
I'm Sorry It Might Be A Dumb Question But I Need Help. What Differences Exist Between A Gear Box In A Manual Transmission Diesel Engine...
Asked by
Shemshem
1999
TOYOTA OTHER
1998 Toyota Hilux 4x4 3ltd Gearbox
Hi I Have Done A Gearbox On My 1998 Hilux And Am Looking At Putting A Recon Or Good 2nd Hand One In . Do I Have To Get One Of The Same Year...
Asked by
moonracker
1 ANSWER
1998
TOYOTA OTHER
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Transmission Replacement - Manual RWD
Wheel Bearing Replacement
Online car repair manuals
