1987 Other Toyota Models Charge light on when using turn sig
1987 TOYOTA
16,000 MILES • 4 CYL • 2WD • MANUAL
NORMANJUSTINDOYAL
Replaced engine fuse at fire wall. Replaced altenator and new battery, and new ignition switch electric harness in steering column. Put battery terminal on and starts right up. Dash lights and gauges on fuel, temp on.
Perfect no charge light on. As soon as I hit the trun signal arm, dead dash and on charge light but its not charging battery. At all even checked with volt meter. Please help me. I do have lights when I twist them on. But slowly die. It quits charging when charge light comes on. I tried to disconnect battery to see if we could start all over but know we cant charge light on.
Jun 6, 2010 at 3:45 PM
Double check wiring connector on back of alternator if ok try wiggle it while engine is running and see if it charges off and on by observing the voltmeter. I have a vehicle that's doing the same thing. If it continues to do it bring it in and have the alternator tested.
Jun 6, 2010 at 6:56 PM
NORMANJUSTINDOYAL
Thank you so very much, if I was a little bit wealthier I promise I would give you some gratuities. I just finished school and I am an older gentleman and its been tough out there with a car problem...... So, "Thank You Very Much" Norman Justin Doyal
Phoenix, AZ
Jun 7, 2010 at 11:07 AM
