1985 Other Toyota Models gas gauge
1985 TOYOTA
128,000 MILES • 4 CYL • 2WD • MANUAL
WILSON280
my gas gauge doesnt work. how do i fix this problem
Aug 2, 2008 at 3:25 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
first you got to see if the wiring harness and the guage is good or if it is a issue with the harness, guage, sending unit.
to do this disconnect fuel pump signal line from the sending unit and ground it out, does it show empty? put on +12v does it show full if not the harness is damaged or the guage is no good.
if it functions properly check the sending unit.
Aug 2, 2008 at 9:13 PM
