1984 toyota diesel
1984 TOYOTA
HAPPYSIDD
lately my toyota has been harder and harder to start i was able to use the primer on the fuel filter to get it started but lately when using it it feels as if its not working and just pushing air at some point it seems to build suction when it does this i am able to start i disconnected the fuel line form the filter with the key in the ignitionand turned on but no fuel comes out i am unsure if there is anything else needed to allow pump to work also will any fuel pump work or does it have to be a diesel pump i believe this is a intank pump is there anything else to check for as far as fuel not pumping ? thank you for any assistance anyone can offer
Apr 17, 2006 at 4:06 PM
LOSONE
  • 1,616 POSTS
Nope you need the exact fuel pump replacement. There are two pumps on mopst models, one to bring fuel from the tank and the other high pressure pump to provide high pressure fuel to the injectors. Good luck.
Apr 18, 2006 at 10:48 AM
HAPPYSIDD
should fuel exit the fuel line feeding the filter when key is in ignition and on or is there a supply and demand type switch somewhere
Apr 18, 2006 at 2:59 PM
