1984 Other Toyota Models Toyota Crown
DOUGCSSX
  • 1984 TOYOTA
  • 6 CYL
  • MANUAL
  • 247,000 MILES
Recently had problem which was corrected by garage,
but was informed that although plugs had been replaced the engine was not firing on all cylinders and probable a problem with the cylinders and would have to remove head to repair do you think there could be some other problem,
Please bear in mind I am residing in Thailand and there may be something lost in translation
Friday, August 29th, 2008 AT 9:14 PM
  • 31,937 POSTS
Hi there,
Have the valve clearances checked & adjusted if required, then do a compression test to see if all cylinder compressions are ok, if not you may have a burnt valve causing your problem, start here.
Mark (mhpautos)
Saturday, August 30th, 2008 AT 2:28 AM
