1984 Other Toyota Models Cooling water
1984 TOYOTA
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOUGCSSX
Slight loss of cooling water must top up every 2 days no external leaks observed
Apr 22, 2008 at 9:11 AM
Using water is a bad idea-If you're not leaking then its being burn in the combustion chamber- Get the cooling system block and pressure tested
Apr 22, 2008 at 11:07 PM
