2001 Toyota MR2 125 code and 171 code
120,000 MILES • 4 CYL • 2WD • MANUAL
CKNAPP360
My check engine light has been off and on for the past cour of months now, it's showing up as 125 and a 171, but I think the 171 Is just a result of the 125. Have had a couple different mechanics look at it and started a thread on a forum about my car. Nobody can figure out the problem. I haven't really noticed any negative side effects but I don't like driving around with a CEL. I'm thinking maybe the O2 sensors or a dirty MAF. I was also told it could be a computer problem. Please help.
Oct 8, 2010 at 8:04 AM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Oct 8, 2010 at 8:09 AM
CKNAPP360
But what about the 125 code? The 171 doesn't even show up thy much, it's more the 125 I'm worried about. Any thoughts?
Oct 9, 2010 at 9:32 AM
  • 75,988 POSTS
Could be an oxygen sensor problem
Oct 9, 2010 at 10:06 AM
