1997 Toyota MR2 Engine cutting out
65,000 MILES • 4 CYL • 2WD • MANUAL
THE FORTRESS
Whenever i remove my foot from the accelorator the enginr stalls. The car is idling below 1000 rpm. why is this and how many rpm should it idle at?
Thanks guys.
Oct 10, 2010 at 8:39 AM
  • 75,988 POSTS
Clean out the idle air control valve and EGR valve and also test the throttle position sensor- Rpm-should be 700-800
Oct 10, 2010 at 9:49 AM
