1997 Toyota MR2
1997 TOYOTA MR2
LUCRAFT
Electrical problem
1997 Toyota MR2 4 cyl Two Wheel Drive Manual 95k miles
hi car cut out on looking theres no spark from dizzy to plugs theres a spark from coil lead to dizzy ive replaced dizzy plus new cap and arm still no change please can you help me regards andy
May 23, 2008 at 3:57 PM
  • 31,937 POSTS
Hi there.
If you have spark at the coil and the coil lead is ok, just make sure that the correct cap & rotor is being used, check the carbon brush in the cap is ok, and the leads are plugged in tight.
Mark (mhpautos)
May 24, 2008 at 2:44 AM
