1996 Toyota MR2 no spark
1996 TOYOTA MR2
LUCRAFT
1996 Toyota MR2 4 cyl Two Wheel Drive 96,000 miles
hi still need help please cannot get a spark after distrbutar theres a nice spark from the coil going into the cap then nothing its had new cap rotor arm leads and a second hand distr still no spark is there a common deeper problem like the ecu going down on these its a 2.0 16 valve sw 20 any help to get me back on the road would be very mutch welcomed
kindest regards andy
May 27, 2008 at 5:02 AM
FERMECH
  • 14 POSTS
Two things can happen either the rotor is not turning inside the distributor or the rotor has a hole sending spark directly to ground.
If you have spark from the coil it should coming out to the spark plugs.
Jun 3, 2008 at 2:42 PM
