1996 Toyota MR2 acceleration
CARSAMUELS
Engine Performance problem
1996 Toyota MR2 6 cyl Four Wheel Drive Automatic
I have a 1996 toyota mark 2 and i am experiencing the following problems and realy needs some advice quicky as no n on this island can seem t figure it out..
Whenever i hit the gas the engine flatters and then shuts off my only way of getting around in it is to be real easy on the gas whenever it decides to finally start then i will be driving and it just shut down on me plus its giving off black exhaust.
Whenever it shuts down on me it takes forever to start, some times i have to disconnect the exhaust sensor then it becomes very loud with a lot of dark smoke.
please help me cause its driving me crazy!!
Jan 30, 2010 at 7:03 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay test the airflow meter, TPS and MAP sensors
Jan 30, 2010 at 7:49 AM
