1993 Toyota MR2 OBD-1 codes
252,000 MILES • 4 CYL • 2WD • MANUAL
TROYTJ
got a 12 AND 71....1st things to replace are???
Gonna start with a distributor cap....any other ideas?
Sep 8, 2010 at 11:07 AM
WRENCHTECH
  • 20,760 POSTS
The 71 is just an EGR code and nothing to do with your problem.
The code 12 is no ignition reference signal to the ECM. This will likely end up being a bad distributor but all the power supplies to it have to be tested first.
Sep 8, 2010 at 11:23 AM
TROYTJ
check engine light is off.....but it will not pass smog in Calif...the smog reading was better than it was before the new EGR valve was replaced...what is up? thank you
Oct 29, 2010 at 5:48 AM
WRENCHTECH
  • 20,760 POSTS
What are the readings and limits?
Oct 29, 2010 at 6:58 AM
