1993 Toyota MR2 crank position sensor``
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
JORDAN417
i am try to find out if my 93 mr2 with a 2.2l has a crank sensor or if it dont. im not getting spark im trying to find a way if there is a way to test any thang to tell y i dont have any spark.
Feb 9, 2010 at 11:57 AM
  • 75,988 POSTS
1993 Toyota MR2 L4-132 2164cc 2.2L DOHC (5S-FE)
LOCATION
The sensor is mounted inside the distributor.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark?
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 9, 2010 at 3:16 PM
