1993 Toyota MR2 1993 MR2 cranks but will not start, no comb
1993 TOYOTA MR2
80,000 MILES • 4 CYL • 2WD • MANUAL
AMUELLER1
hi,
the engine is trying to turn but it wont start.ive have changed already spark plugs,rotor ,distributor cap ,ignition coil and still nothing.
please help?
Feb 5, 2010 at 12:06 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Feb 6, 2010 at 12:17 AM
