1993 Toyota MR2
1993 TOYOTA MR2
CHU
Engine Performance problem
1993 Toyota MR2 4 cyl Two Wheel Drive Manual 100K miles
EMIT BLUE SMOKE IDLE ON UP OR DOWN HILL
but no smoke idle of level road
Mar 1, 2008 at 2:18 AM
MERLIN2021
  • 17,250 POSTS
Compression check the engine, blue smoke is oil burning...if compression is good, valve stem seals could be gone...
Mar 1, 2008 at 2:21 AM
CHU
compression check was ok and valve stem seals replaced tha this problems still occurs. mechanic says its turbo problems ?
Mar 1, 2008 at 6:47 PM
MERLIN2021
  • 17,250 POSTS
So it only burns oil during a boost? Then turbo would be suspect!
Mar 1, 2008 at 10:41 PM
CHU
blue smoke not on boost but on idle and going up at up and down slope
Mar 3, 2008 at 2:22 PM
