1992 Toyota MR2 two questions
180,580 MILES • 4 CYL • 2WD • MANUAL
MORTALTRY
My first one is that my car leaks a blue liquid and just want to know if it could be the transmision fluid? The second is that when ever i turn on my car i have to press the gas to get it started and once i have driving it for a while i can turn it on and of but if i leave it of for about 10 min then when i turn it on it doesnt start unless i hit the gas once and it turns on i was told it might be a fuel injector or the temperature sensor that goes to the ECU?
Jul 29, 2008 at 11:44 AM
BLACKOP555
  • 10,386 POSTS
the blue fluid could be blue antifreeze if that is the kind you have in the vehicle.
with the not starting issue, hook up a fuel pressure test guage and make sure the fuel rail is holing pressure after shut off during the "hot soak"
try this
try turning the key on then off on then off on then off
about 5 times, prime up the line then try to start it, start now?
try turing the key from the off position to start as fast as you can if the above dont work, does this start?
Jul 29, 2008 at 1:01 PM
MORTALTRY
thanks for the response i will try the guage and about the blue fluid its not anti freeze the one it has is green but it does smell like some tipe of oil.
Jul 29, 2008 at 5:02 PM
BLACKOP555
  • 10,386 POSTS
hmm odd. wheres it coming from?
maybe ac oil.'
all the main fluids arent blue, usually just antifreeze.
Jul 30, 2008 at 1:57 AM
MORTALTRY
it comes close to the the drivers side i mean it smells like sometipe of oil its not engine oil from what i can tell because i check it everyday i did check the power steering an that was low. but i cant find were to look to check for the transmition oil on it
Jul 30, 2008 at 11:00 AM
BLACKOP555
  • 10,386 POSTS
chances are it may be a sealed transmission. transmission is red not blue also!
Jul 30, 2008 at 2:15 PM
