1991 Toyota MR2 replace injector seal
80,000 MILES • 4 CYL • 2WD • MANUAL
FASTTOYOTAMR2
I replace my injector seals now my car Idle around 44oo rpm, I tried to replace the tps now it idle over 7200 rpm. ( I have to turn it off so it won't blow)
Apr 27, 2009 at 12:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect idle air control (IAC) valve. Also inspect vaccum lines for leaks/damages. If this problem occured soon after the injector repair then inspect that area really closely for any loose connections or vacuum leaks.
Thanks for using 2CarPros.com!
Apr 27, 2009 at 5:42 PM
