1986 Toyota MR2 Car Stalls when in neutral
172,000 MILES • 4 CYL • 2WD • MANUAL
FLYBOY74656
FYI my car also burns oil. within the past 3 months my car has been stalling at every stop light, every time it is in neutral. I have to re-start the car and keep my foot on the gas to keep it from dying. At first this was happening only when the car has been driving for over a half hour. About 2 months ago I had to pass someone on the highway that was having car troubles and slowing down, so I went into the next lane and tried to excelerate past him because there was fast moving traffic approaching me from behind, while trying to excelerate I was in 5th gear going 35-40mph. After this incident it got worse. Soon after that I realized that the more electronics I had turned on the the car the more likely it would stall (or stall faster). Now about 4 weeks ago after a 45minute trip to somewhere, mostly highway, the alternator broke and was no longer charging the battery (charge light came on the dash). I drove back on the battery, stalling every time it was not in gear. Today I got the alternator replaced and it is still stalling when in neutral. And how much of the electronics are on still affect how fast the car stalls.
I have tried to raise the idle a little bit but it still stalls.
just another FYI: the stalling isn't so bad that I cant shift gears without it stalling, so I mainly stall when at lights or stop signs.
So my question is, why is it stalling? Is my car damaged?
Thank you for any help you can provide.
Mar 1, 2010 at 12:08 PM
  • 75,988 POSTS
Check the fuel pressure if okay -start by cleaning out the idle air control valve and EGR valve and test the throttle position sensor and airflow meter
Mar 1, 2010 at 12:36 PM
