what are the possible causes of an oil leak when spotting appears on the floor and uses about a quart a day?
Dec 24, 2007 at 8:25 AM
✓Experienced Mechanic
Hi there,
that is a big leak! wash down and inspect after a short run, you should be able to see some leaks ,describe where they are, (i know its a tight engine to see into) if you are able jack it up and have a look at front & rear main seals.
Mark (mhpautos)
Dec 24, 2007 at 9:48 PM
