2007 Toyota Matrix Transmission problem, pressure valve or
2007 TOYOTA MATRIX
25,000 MILES • 4 CYL • FWD • AUTOMATIC
SLYSTER
My name is Sylwester Flis and I trully need your help. A year ago I move to Poland for a contract brought my 07T.Matrix with me. About two weeks ago first time I noticed that something wasn't right with the tramsmission. While switching gears from 1-2 and 2-3 it gives sudden jerk. From gear 3 to 4 it wasn't as bad. However switching from anything to R-reverse it gave a huge jolt, and that concerned me the most. One thing I missed for about an hour that at the same time "check engine" orange light came on. I went to local Toyota dealer and the guy hooked up his Intelligent Tester and told me that his software is for european cars and it doesn't allow him to check the problem hoever he deleted the "check engine" light. Well, when I left his lot I noticed that removing the light everything worked great. The next morning "check engine" light came back and the transmission problem with it. While looking for another shop the "check engine" light was off for 4 days which I thought the problem resolved it self, but the light came back on and this time for good. I was suggested to go to a mechanic that works on American cars. I went and he hooked up his OBD tester and this code came up: P0748 pressure control solenoid electrical. First he checked the cables, connections and he found nothing suspicious. Light was off for about 10 miles and it came back on. Next he was going to dig to the pressure solenoid valve but he decided to take a final resistance messure at the ecm plug (that's what I saw). After messuring it he got the right ohmage and that ment that the pressure solenoid valve was ok. His decision was that my ECM is at fault. Obviously that news did not make me happy since I already paid him $200 dollars and the car was still not fixed. Here is my question. Do you think this whole story sound right and make sense. And if it is the ECM how much is it and can the computer be fixed. The mechanic said that he may be able to take a look at the ECM but he doesn't have the blue print or the diagram. And he informed me that it may be the problem here in Poland. Please help me anyway you can. I am a wheelchair user on top of as this makes my problem even larger. I appreciate in advance. Sylvester.
Jul 6, 2009 at 9:55 AM
MERLIN2021
  • 17,250 POSTS
Go back to Toyota and MAKE them fix it for FREE it's under a FEDERAL extended warranty of 96 months or 80,000 miles, here's part of the bulliten on it.
HARSH SHIFT AND M.I.L. "ON" DTC P2716 TECHNICAL SERVICE BULLETIN Reference Number(s): TC015-07, Date of Issue:  September 20, 2007 Superceded Bulletin(s): TC014-06 Related Ref Number(s): TC014-06, TC015-07 ARTICLE BEGINNING INTRODUCTION Some 2005 - 2007 model year Corolla and Matrix vehicles equipped with an automatic transaxle may exhibit a harsh shift condition and a M.I.L. "ON" with DTC P2716 stored. Improvements have been made to the Engine Control Module (ECM) (SAE term: Powertrain Control Module/PCM) to reduce the possibility of this condition occurring. Use the following procedure to repair the vehicle. APPLICABLE VEHICLES  2005 - 2007 model year Corolla and Matrix (2WD) vehicles equipped with the 1ZZ-FE engine. WARRANTY INFORMATION WARRANTY INFORMATION Applicable Warranty*: This repair is covered under the Toyota Federal Emissions Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle's in-service date. *Warranty application is limited to correction of a problem based upon a customer's specific complaint. PARTS INFORMATION PARTS INFORMATION TOYOTA: 2005 - 2007 Corolla & Matrix (1ZZ-FE) SECTION: TRANSMISSION & CLUTCH NOTE: TSB UPDATE NOTICE: The information contained in this TSB supercedes TSB No. TC014-06. TSB No. TC014-06 is now obsolete and should be discarded. OP CODE DESCRIPTION MODEL TIME OFP T1 T2 895011 R & R Engine Control Module (ECM/PCM) Corolla 0.4 89661- ##### 8A 99 Matrix 0.5 Page 1 of 3 HARSH SHIFT AND M.I.L. "ON" DTC P2716 -2007 Toyota Matrix. Tell them to fix it under this NUMBER.
Jul 7, 2009 at 1:14 AM
MERLIN2021
  • 17,250 POSTS
If your local Toyota dealer is unwilling or unable to fix it, then ask them if your guy does it, will they pay for it? Go all the way to the top at Toyota if you have to. Involve the OWNER of the dealership too.
https://images.2carpros.com/forum/automotive_pictures/62217_Matrix_1.jpg
Jul 7, 2009 at 1:20 AM
SLYSTER
You are right, that's the code it came up. I just called the mechanic and he confirmed it. I can not thank you enough. I will be going to the Toyota dealer here in Poland and lets hope he will be able to help me otherwise I will go straight to the Toyota headquaters in the US. Again, thank you.
Sylvester.
Jul 7, 2009 at 2:46 AM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Jul 7, 2009 at 3:37 AM
