2007 Toyota Matrix 2007 Tire Pressure Warning Light
20,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEVALA
  • 5 POSTS
Is there a way I can reset this warning light. I have put 32 lbs. of air in each tire and the light remains on. Any help is appreciated. Thank you.
Feb 10, 2009 at 12:43 PM
DON OLIVER
  • 101 POSTS
sometimes it reads the spare also. did you check it too? a good scan tool will reset the light.
Feb 10, 2009 at 1:01 PM
JOEVALA
  • 5 POSTS
[quote:80532e0afd="joevala"]Computer problem
2007 Toyota Matrix 4 cyl Two Wheel Drive Automatic 20000 miles
Is there a way I can reset this warning light. I have put 32 lbs. of air in each tire and the light remains on. Any help is appreciated. Thank you.[/quote:80532e0afd]
The answer was in the owner's manual although not easy to find as tire information was listed on various pages of the manual. For any of you who have this problem the reset button is located to the left of the steering column. The owner's manual tells you the procedure to reset this dash warning light.
Feb 12, 2009 at 7:10 AM
