2007 Toyota Matrix 2007 Tire Pressure Warning Light
JOEVALA
  • 2007 TOYOTA MATRIX
  • 4 CYL
  • 20,000 MILES
Is there a way I can reset this warning light. I have put 32 lbs. Of air in each tire and the light remains on. Any help is appreciated. Thank you.
Tuesday, February 10th, 2009 AT 8:43 PM
DON OLIVER
  • 101 POSTS
Sometimes it reads the spare also. Did you check it too? A good scan tool will reset the light.
Tuesday, February 10th, 2009 AT 9:01 PM
JOEVALA
  • 5 POSTS
The answer was in the owner's manual although not easy to find as tire information was listed on various pages of the manual. For any of you who have this problem the reset button is located to the left of the steering column. The owner's manual tells you the procedure to reset this dash warning light.
Thursday, February 12th, 2009 AT 3:10 PM
