2006 Toyota Matrix fuses and relays
2006 TOYOTA MATRIX
WAGGIE
Electrical problem
2006 Toyota Matrix
my AC, dash lights, power windows, windshield wipers, shift into gear doesn't work, car does turn on, headlights work but no fogs. radio works.
May 6, 2010 at 5:54 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means engine misfires possible damage to the Catalytic converter...service it right away! You may need to get Toyota to scan it, generic scanners do not read B and U codes which are most likely at the root of the cause.
May 7, 2010 at 10:42 AM
