2005 Toyota Matrix
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOTA2123
When the car shift gears, it makes the engine to shake. The front and rear engine mounts where replaced but that wasn't the problem. The engine light went on.
Jan 26, 2010 at 12:32 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
With this problem we first need to know what the set fault code is, the engine check light has indicated that there is a stored fault code in the ECU, you will need to get this scanned and report the fault code here as a P**** No, this will help me identify your problem, start here.
mark (mhpautos)
Jan 26, 2010 at 12:38 PM
