i have a 1996 75 series toyota landcruiser
350000km 4.2 litre deisel.have replaced radiator ,water pump,thermostat and timing belt to help allieviate over heating.runs alright most of the time .but will over heat under load .then return to normal .will run fine at speed then get hot all of a sudden .slow down speed 10-20 kmph it will slowly return to normal increase speed and will run fine again until the same thing happens again.external temperature seems to make little difference hot or cold the same thing can happen
Mar 1, 2007 at 8:25 PM
