2007 Toyota Landcruiser Air Bag Warning lights on
2007 TOYOTA LANDCRUISER
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
AKRAMHAMMAD
Hi
recently installed alarm and remote start. last night I was working on connecting some of the wires to enable auxiliary output (head lights on ) through the remots. all went OK. however this morning I found that the air bag lights are on. I must have done something wrong.
I tested a lot of wires to find the correct ones. many of them were under the steering column.
any suggestions ??
Aug 16, 2009 at 7:16 PM
  • 31,937 POSTS
Hi there,
You will need to run a scan to see which SRS fault code has been set, do this first.
Mark (mhpautos)
Aug 16, 2009 at 10:19 PM
AKRAMHAMMAD
hi
how to scan ?? what device to use ?
Iam new to this !
Aug 16, 2009 at 10:58 PM
  • 31,937 POSTS
This is something t you should get a mechanic to do, as you will need a scanner that plugs into the diagnostic link,
mark (mhpautos)
Aug 16, 2009 at 11:08 PM
