2002 Toyota Landcruiser VSV for turbo pressure control.
159,000 MILES • 6 CYL • AWD • AUTOMATIC
ABBIY
Hi Tech,
I tested the VSV for turbocharging pressure control on a 1HD-FTE engine as per instructions in the Toyota repair manual RM617E, see below, in step 4 (inspect VSV operation) check that air does not flow from port E to G.
1) Can you please confirm that a VSV valve is NOT operational (useless) if air flows form port E to G and that I need to replace this VSV valve.
Regards
Abdul.
Vehicle Vin # : JTEHC09J207005743.
Engine # : 1HD0230661
Email: Abdul.Khan@hastingsdeering.com.au
Mar 3, 2010 at 11:44 AM
KHLOW2008
  • 41,812 POSTS
Hi Abdul,
Thank you for the donation.
Air should flow between E and G if no voltage is applied to the valve terminals.
If voltage is applied at the terminals, then air should not flow between them.
Mar 5, 2010 at 3:00 AM
