2000 Toyota Landcruiser antenna motor and mast replacement
83,000 MILES • V8 • 4WD • AUTOMATIC
STEVEN_HAM
i need instructions on how to replace the antenna motor(operates intermittently) and mast .. can you help?
thank you!
Jun 11, 2008 at 8:51 AM
2CARPRO JACK
  • 11,533 POSTS
Mitchell has nothing on the r&r procedure for the antennae assembly. If it is in the front fender,I would say that the inner fender liner has to come out to gain access to the motor.If you get a new one from Toyota it will have the mast already in it.Should just be a unbolt and bolt in deal
Jun 13, 2008 at 12:41 AM
