1996 Toyota Landcruiser low pressures on a/c
1996 TOYOTA LANDCRUISER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEPHENR
i am working on a 1996 toyota landcruiser. when i turn on the a/c the pressures are low. the high side is reading 90 psi. the low side is reading 0 psi. i have replaced the condenser, compressor, and expansion valve. and nothing has changed. i have also blew out the lines for restrictions, there are none. i am at a loss. please help. stephen
Jun 16, 2008 at 4:42 AM
KHLOW2008
  • 41,814 POSTS
Hi STEPHENR,
Are you sure you got enough gas in the system?
Check the drier.
Jun 16, 2008 at 5:14 AM
STEPHENR
[quote:41a90331de="KHLow2008"]Hi STEPHENR,
Check the drier.[/quote:41a90331de].
found the low pressure hose next to the exhaust manifold collapsed. now working on a second car, same model. turned out to be the same problem.
Jun 27, 2008 at 7:00 AM
STEPHENR
[quote:39b36e17a9="STEPHENR"]Air Conditioning problem
1996 Toyota Landcruiser 6 cyl Four Wheel Drive Automatic 150000 miles
i am working on a 1996 toyota landcruiser. when i turn on the a/c the pressures are low. the high side is reading 90 psi. the low side is reading 0 psi. i have replaced the condenser, compressor, and expansion valve. and nothing has changed. i have also blew out the lines for restrictions, there are none. i am at a loss. please help. stephen[/quote:39b36e17a9]
fix turned out to be low pressure hose next to exhaust manifold collapsed. had a second vehicle with same problem and fix.
Jun 27, 2008 at 7:02 AM
