1996 Toyota Landcruiser 1996 Toyota Landcruiser value
1996 TOYOTA LANDCRUISER
72,000 MILES • 6 CYL • 4WD • AUTOMATIC
AGOM0603
My Landcruiser blew a head gasket and my mechanic told me that the car needs a new engine. He's showing interest in buying it because he found a used engine to put in it. The car was garage kept, so there's no rust, a few little scratches and dings. The engine only had 72k miles on it. I just put 4 new tires on it, has runners, grille guard, moon roof, roof rack and CD player. Since the engine is dead, how much is the car worth. He's offering $500-$1000 for it. Is it worth more than that?
Aug 4, 2010 at 9:07 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I think your mechanic is trying to take advantage of you, a blown head gasket is not normally a new engine, this can be repaired fairly easily, and the car would be worth a lot more even with a faulty head, i would go get a quote from another work shop to do the head, then make your mind up what you want to do.
mark (mhpautos)
Aug 4, 2010 at 10:38 AM
AGOM0603
What if with the Head Gasket blown, a considerable amount of fluid gets into the engine to render some cylinders from working. I believe the V6 was running on 4 cylinders.
Aug 4, 2010 at 10:41 PM
  • 31,937 POSTS
The bottom end will be unaffected by this, the heads are repairable, but its your decision, if it was mine i would be getting the heads done, i do them regularly on may makes and models in my business, its no big deal, but it's your car, i can only advise.
mark (mhpautos)
Aug 4, 2010 at 11:27 PM
AGOM0603
How much would something like that cost me?
Aug 5, 2010 at 2:10 AM
  • 31,937 POSTS
I will work out an average and post it soon.
Mark (mhpautos)
Aug 5, 2010 at 11:44 AM
PDPYLE
Had my LandCruiser head gasket done for 800-900.00 dollars. Get oem parts and replace all the hoses. go to Ih8mud.com and look for head gasket repair.
Aug 5, 2010 at 1:14 PM
  • 31,937 POSTS
Hi there,
Further To the last post, do not use any magic fix it in a can, these so called fixes can do more harm than good.
Mark (mhpautos)
Aug 5, 2010 at 8:49 PM
