1994 Toyota Landcruiser reqlly wacky electrical problems
1994 TOYOTA LANDCRUISER
150,000 MILES • 6 CYL • 4WD • MANUAL
NIXHIX
Hi there.
The battery is working great, the altenator is fine. The fuses are all great. The dash lights, spark plug lights, clock will work in the accesory position but once you start the truck, they all turn off and then you can still put the key position back to accesory and even take the key out, but the engine won't turn off.
The power locks will try to work, but not enough power to get them going all the way. The power windows don't work.
The rear brake light is on all the time without anything being pressed.
Any thoughts?
May 22, 2010 at 12:41 PM
  • 31,937 POSTS
Hi there, i would be suspecting a faulty ignition switch, and check the brake light switch as well as that sounds faulty also, start here.
mark (mhpautos)
May 22, 2010 at 12:52 PM
