1994 Toyota Landcruiser Replace timinebelt
90,000 MILES • 6 CYL • 4WD • MANUAL
JEFHTWE
  • 6 POSTS
When timinebelt light is on replace the timinebelt but warning light is not trunt of
Jul 15, 2009 at 3:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to reset it. Try removing negative battery cable for 10 minutes then reconnecting.
Jul 15, 2009 at 3:56 PM
LOZZA60
My 1995 4.2 litre diesel manual model has a rubber plug in the glass just to the bottom of the tacho . remove the plug and insert a small flat blade screwdriver into the hole . if you look directly behind the hole you will see a small button .push this with the screwdriver to reset the timeing belt light . be shore to have the engine running or it may not reset .
Oct 24, 2009 at 12:55 AM
