1994 Toyota Landcruiser burning excess gas
1994 TOYOTA LANDCRUISER
CARMANIAC
Engine Performance problem
1994 Toyota Landcruiser 6 cyl Four Wheel Drive Automatic 0km miles
Recently I changed the headgasket and i observed that it is burning far more gas. I aslo recently change spark plug, wire, egr valve, cap and rotor, o2 senser.
I am now fed up with this gas problem. Please advise what you think is the problem and the solution.
Thanlks a million.
Carmaniac
Nov 22, 2008 at 12:52 PM
  • 31,937 POSTS
Hi there,
Back to basics is needed here, do a comp test, check fuel pressure a nd check the rail leak down rate for a faulty injector, check air and change fuel filter, re check timing and do a scan as not all fault codes will have a check light show, check for vacuum leaks, start here.
mark (mhpautos)
Nov 22, 2008 at 1:00 PM
