1994 Toyota Landcruiser
1994 TOYOTA LANDCRUISER
KSTRONG74
1994 Toyota Landcruiser V6 All Wheel Drive Automatic 161000 miles
How do you change the air filter?
Dec 7, 2007 at 4:59 AM
  • 31,937 POSTS
Hi there,
If you have the standard air filter fitted, Undo the wing nut on top of air cleaner, there are 3 latch clips around the rim of the filter housing, unlatch remove vacuum hose from suction indicator and lift top off air filter housing. remove air filter. There is an additional solid particle trap under the main housing, held on with 2 clips, clean this out as well, but be careful when re fitting as there is a locating tap to lie up before it will clip into place.
Mark (mhpautos) :D
Dec 7, 2007 at 2:41 PM
