1993 Toyota Landcruiser Idle
1993 TOYOTA LANDCRUISER
212,000 MILES • 6 CYL • AWD • AUTOMATIC
DERJOBR
Once the vehicle is up to temperature and you stop the lights dim, fan slows and bascially like it is starving for power. If you press on the gas lgithly and increase the RPM (100-200rpm) everything returns to normal. Current idle speed is 650 rpm.
Thaks
Derrick
Mar 3, 2008 at 7:36 AM
  • 31,937 POSTS
idle speed is a tad low... Petrol or diesel engine? you may have a faulty reg in the alternator get that checked as well and check all earth & power connections are clean & tight.
Mark (mhpautos)
Apr 4, 2008 at 12:29 AM
